Guys I'm wondering for a friend of mine what someone would pay for a car:
1988 Alfa Romeo Spider Veloce
Currently needs full paint and body work, interior has crack in dash and slight tears in seats.
Needs a radiator and 2 ac lines.
Past that needs a valve adjustment.
Now for what has been repaired new:
Brake system:
Pads/rotors front and rear, brake lines, brake hoses, brake master cylinder and booster.
Clutch pivot arm and slave cylinder and new braided hose.
Fuel system:
1 new injector, gas tank, both fuel pumps, wiring, sending unit, fuel lines and hoses, fuel filter, fuel pressure regulator.
New valve cover
Full tune up
1 new flywheel sensor
New ignition ecu
new power window switch
new air filter
new injector hoses
new intake manifold coupler hoses
new convert top however back window is no longer clear
vvt rebuilt
new fuel pump and vvt fuse holders.
new radiator hoses and thermostat + housing
new washer fluid hose
new stereo speakers
rear anti-sway bar removed and upgraded larger one installed
newer shocks
new left front outer tie rod
new wheel bearings
new rear calipers
new oil pressure light sensor
all fluids changed and flushed
newer tires
new door bump holders
new washer jets
1) 16511 In-Tank Filter Sock, for a 1988 Alfa Romeo Spider $11.25 1 $11.25
2) 17056 Hose, Fuel Tank Filler Neck $23.95 1 $23.95
3) 17066 Gas Tank, for a 1988 Alfa Romeo Spider
Temporarily out of stock - Expected Ship Date: 10/10/2010
$245.00 1 $245.00
4) 34283 Sender, Fuel Tank , for a 1988 Alfa Romeo Spider $46.50 1 $46.50
FL Tax: $0.00
Shipping - ground: $24.95
TOTAL: $351.65
1) 110960 Rotor, Rear Brake, for a 1988 Alfa Romeo Spider $40.95 2 $81.90
FL Tax: $0.00
Shipping - ground: $15.75
TOTAL: $97.65
1) 16515 Fuel Hose, per Foot, 12mm $3.95 4 $15.80
FL Tax: $0.00
Shipping - ground: $7.95
TOTAL: $23.75
1) 107172 Outer Rod Tie End Set, for a 1988 Alfa Romeo Spider $30.75 1 $30.75
FL Tax: $0.00
Shipping - ground: $11.95
TOTAL: $42.70
1) 01311 Silicone Plenum Hose Set, for a 1988 Alfa Romeo Spider $19.50 1 $19.50
2) 28509 Hose, Top Radiator, for a 1988 Alfa Romeo Spider $9.75 1 $9.75
3) 3803 Rear Caliper Rebuild Kit, for a 1988 Alfa Romeo Spider $16.95 2 $33.90
FL Tax: $0.00
Shipping - 2-day: $20.75
TOTAL: $83.90
1) 03568 Door Lug, Driver Side, for a 1988 Alfa Romeo Spider $13.75 1 $13.75
2) 03623 Door Lug, Passenger Side, for a 1988 Alfa Romeo Spider $13.75 1 $13.75
3) 15516 Vee Belt with Behr A/C, for a 1988 Alfa Romeo Spider $16.50 1 $16.50
4) 4016 Thermostat with Housing, for a 1988 Alfa Romeo Spider $32.50 1 $32.50
5) 40917 Wiper Blade, Bosch Micro Edge Excel 17-inch, for a 1988 Alfa Romeo Spider $10.50 2 $21.00
6) 8250 Drive Belt, Alternator, for a 1988 Alfa Romeo Spider $6.25 1 $6.25
FL Tax: $0.00
Shipping - ground: $17.95
TOTAL: $121.70
1) 16782 Pressure Regulator, Fits only Bosch L-Jetronic injected cars., for a 1988 Alfa Romeo Spider $64.95 1 $64.95
2) 23295 License Plate Light, for a 1988 Alfa Romeo Spider $38.50 1 $38.50
3) 28277 Cap, Radiator , for a 1988 Alfa Romeo Spider $7.95 1 $7.95
FL Tax: $0.00
TOTAL: $132.15
1) 0217 Brake Booster, For 105/115 71-on only., for a 1988 Alfa Romeo Spider $339.00 1 $339.00
2) 0218 Brake Master Cylinder (w/o ABS), For cars with hanging pedals. Reservoir grommets are included., for a 1988 Alfa Romeo Spider $76.95 1 $76.95
3) 25265 Master Cylinder to Booster Seal, Fits #0218 master cylinder., for a 1988 Alfa Romeo Spider $8.95 1 $8.95
4) 8203 Caliper Spring Kit, Front, for a 1988 Alfa Romeo Spider $12.95 1 $12.95
5) 8205 Caliper Spring Kit, Rear, for a 1988 Alfa Romeo Spider $11.95 1 $11.95
FL Tax: $0.00
Shipping - ground: $27.95
TOTAL: $477.75
1) 05281 Brake Caliper, Rear Driver Side, Remanufactured, for a 1988 Alfa Romeo Spider $105.00 1 $105.00
2) 05281999 Brake Caliper, Rear Driver Side,Core Charge
For information about cores and core charges, please see IAP Core Policies $95.00 1 $95.00
3) 05282 Brake Caliper, Rear Passenger Side, Remanufactured, for a 1988 Alfa Romeo Spider $105.00 1 $105.00
4) 05282999 Brake Caliper, Rear Passenger Side,Core Charge
5) 1108 Air Filter, For Bosch fuel injected cars., for a 1988 Alfa Romeo Spider $22.95 1 $22.95
6) 40283 Windshield Washer Jet, for a 1988 Alfa Romeo Spider
Temporarily out of stock - Expected Ship Date: 1/20/2011
$3.90 2 $7.80
FL Tax: $0.00
TOTAL: $458.70
1) 06294 Braided Stainless Steel Clutch Hose, All, for a 1988 Alfa Romeo Spider $28.50 1 $28.50
2) 06751 Clutch Pedal Pivot Pin, for a 1988 Alfa Romeo Spider
Temporarily out of stock - Expected Ship Date: 2/1/2011
$69.00 1 $69.00
3) 34266 Switch, Reverse Light, for a 1988 Alfa Romeo Spider $13.50 1 $13.50
4) 66665 Gasket, Valve Cover, Reinz (German), for a 1988 Alfa Romeo Spider $19.50 1 $19.50
FL Tax: $0.00
TOTAL: $148.45
1) 1801 Clutch Slave Cylinder, for a 1988 Alfa Romeo Spider $43.95 1 $43.95
2) 25404 Clip, Clutch Slave Cylinder, for a 1988 Alfa Romeo Spider $1.85 2 $3.70
FL Tax: $0.00
TOTAL: $59.60
1) 34264 Sender, Oil Pressure Light, for a 1988 Alfa Romeo Spider $5.95 1 $5.95
FL Tax: $0.00
TOTAL: $13.90
1) 22751 Magnetic Flywheel Sensor, for a 1988 Alfa Romeo Spider $85.50 1 $85.50
FL Tax: $0.00
Shipping - 2-day: $17.95
TOTAL: $103.45
Thats not everything either, there is about another $2000.00 in parts from other various venders...... Theres also more parts under my friends international account as well from over the years. I'd say at this point including new $8000 in repairs id say over the past 5 years he has over $10,000 into this car.
Total investment thus far around $8000.00 in the past year, and car has not been driven yet using new parts, car has been and currently still is at my shop.
I realize this is way more then will return so please lets not go there, this has been a car where I have started fixing one thing then another breaks or already is then is found so my friend never expected to invest so much and no at this point it is very deep in the hole money wise.
With that said what would be expected to profit from this car, anotherwards what about price would it sell for?
And better yet is there anyone that is interested in it and making a serious offer?
I have done all I could to have tried to get my friend not to invest in repairing this car however he did anyways and thus needs to be able to sell to recoupe some of the lost funds.
Brake system:
Fuel system:
New valve cover
Full tune up
New ignition ecu
new air filter
new injector hoses
vvt rebuilt
new stereo speakers
newer shocks
new wheel bearings
new rear calipers
newer tires
new washer jets
$245.00 1 $245.00
FL Tax: $0.00
TOTAL: $351.65
FL Tax: $0.00
TOTAL: $97.65
FL Tax: $0.00
TOTAL: $23.75
FL Tax: $0.00
TOTAL: $42.70
FL Tax: $0.00
TOTAL: $83.90
FL Tax: $0.00
TOTAL: $121.70
FL Tax: $0.00
TOTAL: $132.15
FL Tax: $0.00
TOTAL: $477.75
$3.90 2 $7.80
FL Tax: $0.00
TOTAL: $458.70
$69.00 1 $69.00
FL Tax: $0.00
TOTAL: $148.45
FL Tax: $0.00
TOTAL: $59.60
FL Tax: $0.00
TOTAL: $13.90
FL Tax: $0.00
TOTAL: $103.45
