Losing storage space so my project must go. This is a (rough) running project car. 2.0 Litre Engine, Bosch electronic fuel injection. 5 speed manual transmission. Odometer shows 111k-ish miles, but the speedo/odometer has been intermittent so hard to say how accurate that number is. Mechanically it is in fair condition. The engine does not burn or leak oil. The 5 speed manual transmission shifts without any grinding. The brakes work, but could use some attention. The exhaust manifold is cracked, but a good used replacement is included with the car. There is some rust damage in the spare wheel well of the trunk. The previous owner said the battery (which lives in the trunk) came loose and spilled acid, which caused the corrosion/rust. Repairs were started with some sheet metal, but the project needs finishing. The rust is not structural, nor is it visible unless you look underneath the rear of the car. The electrical system lives up to its Italian car reputation. The previous owner had the ignition circuit tied into the parking light circuit, and I suspect this was done because of a wiring harness issue. The driver side power window is currently non-operational. Various interior bits are cracked or otherwise in need of attention. The carpet and seats are in pretty good shape. The canvas top is in good shape, but the vinyl window has a crack. The body/paint looks really good from 20 feet away. The closer you get, the more flaws you see. A good buffing would probably solve some of the issues, but there are a few dings and scratches.
$1000 or best offer.
