1 - 2 of 2 Posts
My Quad is not driven much. Last few times, the clutch will allow me to shift gears but the transmission doesn't engage. It is as if it is stuck in neutral. Then when it feels like, it will allow me to engage and start moving. Other times it will rev up and then slowly dump into gear. Could be stuck throw-out I assume. The clutch has about 10,000 miles on it. All the fluid levels look good. There is a noise coming from front engine/tranny area when I engage the clutch- could be the throw-out bearing noise? Just looking for most likely culprit as to what is going on. With the low miles, I didn't think it was clutch. TOB, slave or master? Any ideas?
· Premium Member
I'd check the hydraulics first. Have someone sit in driver seat and press the clutch. Watch the piston on the trans and see if it extends 5/8 inch or so. Have em hold pedal down and see if it stays extended. Then release the pedal and see if it returns quickly. If hydraulics check out I would suspect clutch is bad ( fingers broken off)
1 - 2 of 2 Posts
