1986 Spider parts - everything is gone
Everything was sold or given away - nothing left
Too many parts for individual pictures. Unless it says Sold, I'm open to offers to everything on this Picasa page:
https://picasaweb.google.com/104200019835390970668/86Spider?authkey=Gv1sRgCPKBrPD1ud6-Cw&noredirect=1
New additions in Bold
Vacuum sensor
Gas tank cover
Map pockets
Door reflectors
Interior door handles
Armrests
Steering column shroud
Dimmer switch
Speedo and Tach shrouds
Top dash vents
Cowling
Center console panels
Alternator
Firewall grommet
A/C system
Fuel injector rail
Thermostat housing
Turn signal housing
Hood release bracket
Headlight buckets
Rusty oil vapor separator
Starter
Shift shaft
Tranny shifter cover
Heater box
Heater vents
Engine wiring harness
Seat hardware
Center console
Center console wiring
Emissions box in trunk
Gas inlet
Intake manifold
Header
Wing windows
Gas pedal assembly
Sway bars and mounts
Center link
Emergency brake cable
Tranny exhaust mount
Driveshaft
Bunch of trim pieces
Gas door
Rear lights (rough)
Hood hinges
Emergency brake handle - cracked plastic
Wiper motor
Gas tank sending unit cover
Power Window motors and accessories
Power window emergency crank
Vacuum sensor
Gas tank cover
Map pockets
Door reflectors
Armrests
Dimmer switch
Top dash vents
Cowling
Alternator
Firewall grommet
A/C system
Fuel injector rail
Thermostat housing
Turn signal housing
Headlight buckets
Starter
Shift shaft
Heater box
Heater vents
Seat hardware
Center console
Gas inlet
Intake manifold
Header
Wing windows
Gas pedal assembly
Center link
Driveshaft
Gas door
Rear lights (rough)
Hood hinges
Wiper motor
