Have a cracked head and leaking coolant!! Crack initially started small, just below head bolt, and now is clearly visible and working its way to the plug well which fills up with coolant... After re torquing I now have a massive oil leak - pukes out while idling - at the rear of the head, drivers side. I figure if I need to replace the head gasket I should probably go ahead and replace the head as well. Any good, serviceable heads out there? Pacific NW area? Any leads appreciated. thanks,
Erin
206.789.2354
Erin
206.789.2354
