1 - 5 of 5 Posts
Hi guys
I recently acquired a 1986 Alfa spider Veloce, and I have been combing through the car and electricals.
The two interior foot/floor lights on the driver and passenger side do not work, and I would like to access the area behind the panels to assess the problem.
Can anyone please shed some light on how I can go about accessing the electricals behinds the centre console safely.
Thanks in advance
Vassili
Welcome to the BB.
Are you sure the lights are not working? The lens acts as a switch it rocks or tilts to three positions - automatic (on/off with the doors), always on & always on.
There is also a light timer relay in the fuse box. If the timer relay goes kaput the lights don't work in the automatic position (but I think they should still work in the always on position). And the door jamb switches can get corroded causing the automatic function to not work.
To answer your question, hmm, I can't remember... I think the light unit pries out of the console. But it might be better to wait for a reply from someone who knows for sure.
Yes, they just pull out as a unit. My advice is to cleanup the contacts on the door switch. That was key to getting my pass. side working. I still need to work on the ds one.
Sent from my SM-T710 using Tapatalk
Success
Thank you!! I have fixed the lights. It turns out the driver side light worked and the passenger side needed a bulb.
1 - 5 of 5 Posts
