I have been working on this 85 for my son for about a month now. New floors, inner fender wells repaired, new timing belt and tensioner, rocker cover gaskets, new hoses, general tune up bits, radiator boil out and test, power coat exhaust manifolds, front and rear brake pads and discs and now I am moving to fix the sloppy gear linkage.
I have removed the exhaust, disconnected the linkage below the shift lever and have driven out the roll pin on the shift rod using a rivet gun and backing it up with a bucking bar...worked great...
But now, I cannot separate the rod from the link arm attached to the transmission....any help with this would be appreciated.
Thanks Ed
Thanks Ed
