501 - 520 of 1396 Posts
You can get away with picking up seals and taking them somewhere? The ones around here would put up a real fuss, to be sure. Might get your hand bitten off, lol.
:D
Reminds me a joke involving a penguin returning to his car at a repair shop after just finishing an ice cream, and being told it looks like he has blown a seal ...
Discussion Starter #502
I have achieved success.
Pictures soon.
Discussion Starter #503
I'd end up needing a rabies shot and probably throw my back out. No good.
:grin2:
Discussion Starter #504
Set an appointment with CA DMV for September 11. For final licensing of the car.
Now, need the smog cert and the brake and light inspection. (Or course the car doesn't run at the moment and there are no front headlight or indicator lights) Already insured.
Bob
Discussion Starter #505
I'm trying to search and find any threads on GTV6 anti-dive for the front suspension. Anyone know of any?
Bob
Discussion Starter #506
If anyone is in the market, Tire Rack has a closeout on some 16" 5x98 wheels that are supposed to fit the GTV6.
Bob
Reactions: horsewidower
Discussion Starter #508
This is designed in to the front suspension. Usually by angling the inner wishbone suspension pick up points so that when you brake you are (not?) compressing the front spring.
I understand how it works, I've actually designed road race front suspension. I'm really just being lazy, here. I don't want to go through the hassle of doing all the measuring work to come up with my own solution if one has already been scienced out by someone else. I see a lot of information about dropped spindles, some discussion of fiddling with the standoffs on the LCAs for fiddling with camber, but haven't seen much on changing attachment points on the upper control arm.
Just wondering...my friends tell me I spend too much time thinking and not enough time doing.
I thought the stock suspension was good enough for pretty sporty driving. One can spend time and money screwing around with something some may think is better, but in reality, stock is pretty good. Lol, you don't want to be the next dreaded PO. Just a thought. You are doing a great job on that restoration. Be proud.
Discussion Starter #510
Your point is well taken.
Sometimes I wander a bit.
And then the GTV may get some attention again ... :)O
Reactions: bulletpruf
Discussion Starter #513
Discussion Starter #514
Well, I just had the thoroughness of the brake and light inspection described to me...I have a lot of work to do.
Discussion Starter #515
Summary:
Thats quite the journey for wheel seals. I got my seals from Centerline, they were the right ones, made in Italy, fit first try. Glad you finally got it sorted. On to the next!
Sent from my SM-G935V using Tapatalk
Discussion Starter #517
I looked at Centerline's website a couple of times during this journey, didn't see them listed. I should have called.
Discussion Starter #518
Working in driver's side suspension. Basically a "wash, rinse, repeat" of the passenger's side. UCA bolt was a bit stuck but was "persuaded" to slide out. Everything is soaking in cleaner, paint tonight.
Discussion Starter #519
Fiddling with headlights for the non-stock portion of this car's life. I ordered a couple of these with the integral turn signal.
Haven't seen these before. Legal in Cal?
