1 - 2 of 2 Posts
I need a ECU with a Part # of 0 280 001 117. Or an ECU that will work. I assume that it is the ECU cause the injectors are not opening. I am getting a 12 Volts from the relay and out but none to the injector. If you might think it is something else. Please let me know
I have a couple of ECUs off 1983 GTV6s: Jetronic #0-280-001-113. Also, a couple from 1986 GTV6s... but I don't have them here to check the numbers to see if they are the same.
If you decide the problem goes back to the ECU, I should be able to help. I'm not a mechanic, so I can't offer any diagnostic advice. See if anyone else can offer that.
You can contact me directly at: [email protected]
... if you decide your ECU is the culprit.
Cheers, Peter
1 - 2 of 2 Posts
