1 - 1 of 1 Posts
Ok I purchased an RML distributor and coil from Ric. I want to say how awso Ric has been to help me out. The best customer service I have seen in a very long time! So I am having one issue that I need a little help with.
i have the RML installed per the instructions. Fired the car and nothing. Crazy, turned out that if the distributor is connected to the positive and negative side of the coil and when you turn the ignition to on, I do not hear the drive relay click nor do I hear the pumps prime. If I unhook it from the coil, the relay clicks and the pumps primed. So with Ric’s suggestion I pull from another power source. I did and the car fired up. Any suggestions on why it would not power the relay and pumps connected to the coil? The big white wire is disconnected and I have around 12.5 cranking volts
1 - 1 of 1 Posts
