Moving sale...
Car runs and is driven around the block regularly to keep it limber. It can be driven and enjoyed as is but, needs cosmetic work. It's been a fun car and I am a little torn to sell it but a potential move means that now it needs to go.
What's been done:
Recovered front seats, door cards and parcel shelf. Paul Spruell engine mounts installed. New oil separator installed. All rubber brake lines replaced. All rubber fuel lines replaced. New in-tank and main fuel pump replaced. New fuel filter. Left and right door check straps replaced. Dual horns installed. Clutch master cylinder and clutch arm pivot lever replaced. New outside rearview mirrors replaced. New front and rear Alfa Romeo badges added.
The Issues
Rust on the driver door sill. Rust under the passenger seat on the outer panel, the inner panel is ok. Rust at bottom of right rear fender. Rust in spare tire well. Exhaust leak somewhere. Convertible top frame needs a cross bar spot welded back in place. Shift lever gaiter needs to be reinstalled.
More Info
I've only added two photos to this listing, but there are many more pictures on Imgur Just ask and I will take pictures of anything else you want to see.
YouTube videos of the car
Clear title. Car does not have current TX registration or inspection. 71,613 on the odometer. Sale includes Parrish aftermarket hard top and new vinyl top that needs to be installed.
Click here for more pictures on Imgur
Make an offer. Shipping is not included, but I will assist in getting it to you.
