1982 Alfa Romeo-Spider Veloce (Bosch FI) ITB SCCA Race Car
For Sale:
1982 Alfa Romeo-Spider Veloce (Bosch FI) Race Car
SCCA ITB-Midwest Division #38
SCCA Log Book 13-585, 2010 Annual Inspection
Photo attached below. See full set of pictures here: 1982 Alfa Romeo Spider Veloce for Sale - a set on Flickr
$15,000 car only
$18,000 complete
Features:
Spares:
Also Available:
Driven and impeccably maintained by lifelong Alfa owner and enthusiast.
Contact:
Bernie Mermis
email: [email protected]
phone: (316) 691-8170
Located in Wichita, Kansas
For Sale:
$15,000 car only
$18,000 complete
Features:
- Charcoal Metallic with Silver Graphics
- Weight 2230 lbs (includes 40 lbs ballast)
- 1974 front & rear bumpers and grill
- Alfa Romeo Campagnolo “Daytona” magnesium 6 x 14 wheels (12 total)
- Four new Avon Tech DOT 205-55 x 14, mounted (+2 used spares, mounted)
- Six used Hoosier RS DOT 205-55 x 14, mounted.
- Alfa Ricambi/Shankle fiberglass front spoiler
- SCCA (2008 legal) 6 point custom roll cage (with NASCAR door bars)
- Simpson 6 point restraint system (expires 12/08)
- Driver’s side net
- 4 panel Wink mirror
- 1 ½ lb dry chemical fire extinguisher
- 12 inch Speedline steering wheel
- MOMO “Rookie” Race Seat
- ATL “Sportsman” 8 gallon fuel cell (Fuel check port in trunk)
- Two AC low pressure fuel pumps to Bosch HP pump
- Electric “cut off” safety switch
- AMB Transponder
- Insulated battery box (trunk location)
- Gauges: AR tachometer, AR water temperature, SW oil pressure, VDO oil temperature
- Engine oil cooler (EARLS)
- Electric radiator fan (SPAL)
- K&N “Cone” air filter
- Shankle Exhaust Header (Muffler and side exhaust)
- Driveshaft “Donut” safety guard
- Beck “Orion Motorsports”: Front springs, rear springs, adjustable camber upper control arms, rear mounted front sway bar, adjustable rear sway bar, bolt in Panhard rod - forward mount & link
- Alfa Romeo “Unibal” rear lower control arms
- Koni Sport “Yellow” shock absorbers
- Braided steel brake lines
- Porterfield R-4 brake pads
- Alfa Romeo LSD (4 clutch) 4.56 ratio
Spares:
- 1982 engine
- Holiday Canopy, 10’ x 20’
- Brake pad set
- Custom Vinyl ****pit cover (for open trailer towing)
- Steering gearbox/shaft
- Water Pump
- AC fuel pump
- Bosch fuel pump
- Miscellaneous hoses, belts, parts
Also Available:
- 1976 Steverson tandem axle trailer with self storing ramps, tire rack, storage box, adjustable load equalizing hitch
- SA 2000 Bell Helmet (Large), driver’s suit (Medium) and bag
Contact:
Bernie Mermis
