Good afternoon Alfisti!
Included in this parts lot is a 2 liter engine and 5 speed transmission originally from a 1981 Spider. The engine ran when pulled, but not well. It was in the process of being converted to an earlier version of Spica injection from the difficult to work with single butterfly system originally installed on the '81 models.
A rare inclusion in this year's engine is variable intake CAM timing that is driven by oil pressure, not controlled by an ECU. This required a CAM cover with a larger section over the CAM gears.
The car was originally fitted with AC so the front cover plugs have large studs sticking out from them that could be used to mount a bracket should you need to.
Both Spica intakes and air filter canisters are included. Also included are assorted related parts... shift knob, shift lever, boots, etc.
Not interested in splitting this up, or particularly in shipping anything. Parts are located in Northwest Indiana in the Chicagoland region.
Asking $1300 or best offer.
Thank you for your consideration!
- Jim
Engine & Trans 01.jpg Engine & Trans 02.jpg Engine & Trans 03.jpg Engine & Trans 04.jpg Engine & Trans 05.jpg Engine & Trans 06.jpg
Looks like it's time to drop the asking price a little... the initial post has been updated. :)
- Jim
