1 - 11 of 11 Posts
Hello all, Is there a specific procedure for replacing a starter motor.
I can't seem to get my socket onto the nut or bolt head.
There is not enough room. Does the engine need to come out?
Might get a response sooner if you post this in the spider postings
Richard Jemison
Starter
Using a very long extension you can remove the upper and lower bolts from the front of the engine.
The middle shoulder bolt with open end wrenches.
Senior TEXAS member
Socket on the transmission side, open ended/box wrench on the front side.
Dont misplace the shoulder bolt or the washers....
I just went through this on our Berlina. It's a PITA if the bolt heads are 17MM, very little room for a wrench. I ended up using a combination of 17mm and 13mm wrenches. I couldn't get a socket on either side. I pulled the vacuum hose barb off the manifold and that allowed me to get the top bolt free.
Once they're off you can usually replace or remove again in about 5 min. Took me an hour the first time.
thanks, I was able to get it out.
Now I have to find a starter. Looks like they only have rebuilt ones now.
Call Alfa Parts Exchange, they have lots of used ones. I just got a quote today for $70 plus shipping. 209-365-1383
Of see if a local shop can rebuild yours.
Consider using an 86 -89 starter. It is a straight replacement and it does not need the support bracket because it is lighter. If you use the original starter without the bracket then you risk breaking the bell housing.
1 - 11 of 11 Posts
