1979 Alfa Romeo Spider 2.0L 4 cylinder with 5 speed transmission. Resent complete rebuild. Original California car with engine and transmission rebuilt by Andrew Watry with John Norman prepped cylinder head, Motronic 10/1 compression piston/liner kit, Euro 10548 camshafts, early 2L headers. New RML reprogramed electronic distributor/cap/wires. Updated properly with Weber DCOE carburetors, stacks and large air cleaners - performance upgrades. Complete original Spica system included.
Cosmetic and complete mechanical update 3/4 years ago. Fresh red paint. Complete chassis rebuild including lowered suspension, Koni Red shocks, all new suspension bushings installed, adjustable upper A Arms, all ball joints and steering links, rear suspension links, sway bar bushings replaced, steering box adjusted. Rear trailing arm and upper link bushings installed. Suspension components cleaned and painted during build. New exhaust system and hangers. Proper alignment with camber, caster and toe adjustments set. All fluids recently changed. Fresh 4.10 Posi rear axle installed. SS brake lines. New 185/70/14. Kohmo tires on factory Campagnolo Alfa alloy wheels. Bumpers recessed for improved visual looks. Electrical system works properly. Top and rear window in good shape – no leaks. No rips or tears in upholstery and interior.
Currently has two cracks in the dash top, the console, heater system/controls have been removed and top header vinyl/foam pad worn .
Super clean body and chassis. Original floors, jack points and trunk – no issues or rust. Recently only driven in the summer months in central New York.
Not a show car but drives, handles, rides and performs exceptionally well.
$9500 or best offer
Thanks Chris D
More photos coming
$9500 or best offer
Thanks Chris D
More photos coming
