Is the clutch master cylinder fluid level OK?
Describe what is & isn't happening.
Does the pedal feel normal or very loose? Where does the clutch pedal rest as compared to the brake pedal? (? broken pedal pivot ?) Empty fluid reservoir &/or any puddles under the car? (? leaking slave cylinder ?)
No puddles/full reservoir & pedal looks/feels normal perhaps the clutch disc is stuck to the flywheel by rust.
Also, we need pictures!
(Are you slipping Eric?):confused:
Good deal! The leak is most often the slave cylinder. Luckily it is a simple design, easy to rebuild or replace. There are two brands of cylinder possible. You might want to replace the flex hose at the slave during the repair.
