How long should it take for a competent Alfa mechanic to remove the windshield from Aaron 1974 GTV without breaking it (which I know is tough)?
Just removing the trim without scratching the finish (car and trim) is a talent. Unfortunately, removing the glue in windshield is not an easy task.
how can you tell if your windshield is glued or not? On my 2000 gtv -75 it looks like it´s not glued. There´s a "lip" like on the rear windshield, where i used a plastic butter knife and pryed the lip to the other side of the frame. If the windshield is glued, does it have that moulding with the "lip" inside the car?
I had a professional take mine out and it was 10 minutes tops, he cut the seal and through all the mounting sealer and it came right out.
