Several years ago I replaced the front driveshaft support and bearing as the support rubber had deteriorated. Now, when I am finally getting around to reinstalling the driveshaft, it is about ¼ inch short of meeting the transmission guibo donut. I also replaced the engine mounts but did not replace the transmission mount, so the engine should be in the same location. I also replaced the guibo, but the dimensions of the new one are identical to the old one. At the driveshaft bearing there is a “spring spacer”. Does this spring go forward or rearward of the bearing? I presently have it to the rear of the bearing. I’m pretty sure that is how I found it when I did the bearing replacement – but I could be wrong as it was several years ago when I did the work. I am the original owner, so I can’t blame a PO. It does not appear it matters which way the bearing support is installed as it appears symmetrical. Any help would be appreciated. Thanks,
Jim
Jim
