1 - 15 of 15 Posts
I am selling a 1974 Alfa Romeo GTV 2000 that has just finished being restored. Not a ground up but body, paint, interior, all rubbers, fixed all electrical on and on. No, I do not have pictures readily available as I used a cheap throw away camera but will provide if someone is truly interested. I will get a friend to take some pictures. I would rather discuss on the phone all that has been done --- so call me at 1-310-331-7424 if you would like to discuss. The price 22,000.00. Thank you for the listing. Southern California.
A picture is worth a thousand words...
Some pics could spark interest....:eek::D;)
More details too - color, condition of motor, miles etc.
Discussion Starter · #4 ·
74 Alfa
Working on the pictures ---but will address the questions --- again calling much better then e-mail--- The color is burgundy, full respray, all glass was removed, all new seals, all new interior - black interior, all gages repaired, original radio repaired including cassete. Tran and motor rebuilt by last owner approx.30k on each. All electrical works, starter/alt./fuel pump rebuilt. Hope this helps...
I have to admit that with the slight delay in sending pictures i was not expecting to see such a sweet example. I love them in maroon. I will be in the market to purchase my first in about a year. Wish i was ready now as your car is just what i will be looking for. Good luck with the sale, it must be tough to let her go.
Discussion Starter · #9 ·
Gtv
The fellow BBer that called on Friday please call again and this time leave your telephone number clearly--your cell phone was breaking up. And yes I would take 20K for the car.
Is this car still avaliable?
If so, what is the top offer ?
I am a long time GTV owner and I am looking for a fine example.
Herb
Discussion Starter · #12 ·
74 gtv
1974 Alfa Romeo Repairs
Trunk
Rust was removed from the trunk area and re-sprayed. The spare tire area was sanded and primed and then treated with chassis undercoating. Trunk boards were re-done to cover the spare tire. The original side boards are there as well as the original wool carpet verified by a few moth holes
Gas Tank
The gas tank was removed, all rust fixed and the entire tank sealed. The original fuel sending unit was rebuilt and recalibrated. -. New stainless steel hardware installed
Fuel Pump
The fuel pump was rebuilt and new rubber isolators were installed.
Fuel Hoses
All rubber fuel hoses were replaced with new ones.
Rear Suspension
Rear suspension was replaced shocks and springs by Red IAP Koni/Spring Package
Rear Tires
New rear tires
Brakes
Stainless steel brake lines installed
Rear Lights
Rear lights were replaced new bulbs and new banjo connectors. Also, used Ferrari 308 license lights to replace the old painted over license lights.
License Holder
Rear License holder bead blaster and painted
Rear Bumper
Rear bumper removed de-dinged and polished. New hardware installed
Antenna
New antenna installed – manual
Jack and Tools
Jack sanded and repainted same for the tools and a new tool pouch
Exhaust Systems
Totally redone – removed a section as it was too loud - Stainless exhaust except where the section had been removed - installed an aluminized pipe.
Rear Differential
Fluid removed and replaced with new fluid.
Interior
Total interior replaced with black ---- not following the boring pattern of the original design. New headliner and yes the windows were all removed to do the job correctly. The door panels are out thin gage plywood and marine varnished to prevent warpage. The plastic chrome handles were re-chromed at an extremely expensive procedure. Rear shelf totally redone and recovered.
Dash
Sent out to have the dash totally refurnished. Did not reinstall the wood finish.
Gages
Sent out all gages, cleaned, recalibrated, and polished. The binnacle does not have the broken ears as many do.
Becker radio
Rebuilt including the cassette deck.
Seat Belts
New front seat belts. Did not install rear seat belts.
Interior lights
Did not re-install the interior lights on the side post. So no side post interior lights.
Center Console
Center console re-done all switches and lights work including the lighter.
Heater Core
Heater core redone –new shut-off valve –manual valve under dash for a cleaner looking center console look. All new hoses and grommets. No windshield defroster tubing.
Windshield Washer
Original bag - not connected.
Heater Fan
Heater fan rebuilt
Windows
All windows tinted. All new rubber gaskets around the windows. All windows functional.
Engine
Rebuilt 30K, rebuilt radiator/starter/alternator, new ignition, new speedo cable, new tach cable, see past owners repairs
Battery
New battery
Fuel Pressure (SPICA) Override Switch
Installed override switch
Transmission
Rebuilt 30K see owners past comments
Front Bumper
Polished, de-dinged and installed new hardware
Front Lights
Hella Driving lights/Bosch Fog lights
Front Grill
New front grill
Front tires
New front tires
Front suspension
IAP Red Koni shocks and springs
Lug Nuts
All new lug nuts
Total Repaint
All rust removed panels cut were needed, painted original 1974 color
Floor Boards
Both floor boards removed, replaced and resealed, including dynamat covered
Brake/Clutch pedals
New brake/clutch pedal coverings
All issues addressed and fixed.
*All above information backed by receipts from present and past owners.
1 - 15 of 15 Posts
