1 - 5 of 5 Posts
Looking for a valve cover vent, right hand- large hose exits rearward.
The previous owner of my 73 spider converted to Webers many years back. The valve cover vent on my car exits to the Left- forward. It's obvious a straight vent was cut at a 45 and welded. It does make for easy routing under the upper rad hose to a catch can. They had their work done by a reputable race shop which would explain the set up.
I'm going to a Euro airbox and need a rearward exit for the vent. I know there are some out there, or if someone would want to trade? Thanks, Steve.
Can't you just remove it and flip it around?
Sent from my GM1917 using Tapatalk
That was my initial thought, but as you rotate it 180 degrees the mounting flange is then angled away from the valve cover.
1 - 5 of 5 Posts
