Happy Holidays All - I hope many of you are reading this as a small break from hanging out with your families or working in your own garages. I am working on a few posts in different areas. My primary focus this winter is on replacing the majority of rubber bushings in my suspension, and I'll build a post on that later. In the back of my head, I know that I have a bigger problem (or at least I think it is...) related to my engine, and I am concerned that my novice abilities are not up to the challenge. I have no Alfa mechanics nearby, so would like to troubleshoot and solve myself. Of course, some help from the Alfa BB would be much appreciated! A few have already offered to help (Thank you!) but I thought sharing my problem for the Alfa BB world to see might be the best benefit for all.
I'll start at the end. Just before my Berlina was pulled into the garage for the winter, to be placed up on jack stands for all the bushing work, I took her for a final spin. She had been having some engine issues, but I need a last spin.
And because I know everyone likes them... Here is a pic or two of the engine bay.
- 1973 Berlina 2 liter with ~96,000 miles. Unsure whether it's turned over.
- Converted to Webers prior to my ownership.
- She idles between 800-1000 rpm once warm.
- Around 3000-4000 rpm in any gear, the engine begins to miss, or something... I am not experienced enough to describe it correctly. The car lurches or jerks slightly. Something is definitely not right.
- If I let off the gas, I can get where I am going, but she's not happy....
- Under 3000, she sounds OK....
- Purchased a well-cared (I trust the previous owner and he seemed to know the car well) for Berlina in July of 2020 and drove 1300 miles home. No engine trouble, but some blue grey/blue smoke seen towards the end of the trip on downhills when letting off gas.
- Driving that summer was great! Car pulled well. Grey/blue smoke seen both under hard acceleration and on downhills, but car ran well!
- Black sort of sticky soot comes from the exhaust. Not terrible, but enough that I clean it off the rear driver's side 2-3 times a year. If you stick your finger in the end of the exhaust, there's a fair bit of this black soot.
- Burns about 1 qt of oil every 400-500 miles.
- I use ethanol free fuel. The original owner swore by Chevron Techron fuel additive. I used this for awhile, but was convinced by my local mechanic to switch to Marvel Mystery Oil. I have also run without either at times... I'm not sure if either additive helps.
- Switched from Castrol GTX 20W-50 to Valvoline VR-1 20W-50 (Again at the recommendation of my local mechanic (He's very good, but more of a German car guy... Doesn't really like Alfas, but he's all I've got.)
- Drove the car 2 hours to an expert in York. Car ran great on the way down (75-80 mph the whole way!). In York, we identified all the bushing work that needed to be done. Expert took the car for a spin, and was only really concerned about the suspension bushing work that needed to be done. Really, beyond knowing that rings and valves were probably needing some work at some point, the engine was still running well...and then...
- On the drive home from York, we were cruising along at the same 70-80 mph and having a great conversation... and then I felt a little skip or hesitation, so small that I am not even sure my co-pilot noticed. But I think everyone know that feeling..like... ohhh, what was that?... Please let me get home and off the highway... There were a few more of these small skips, but we made it home fine.
- Once home, I replaced the cam cover gasket to solve a small oil leak. At the same time, I made a very small tightening of the timing chain and checked the cam/valve clearances. I also replaced the front fuel filter, the rear look nearly brand new. All this seemed to go well.. clearances were acceptable and car ran alright although...
- The skipping/missing/lurchy behavior started to become more noticeable when accelerating hard in 4th... sort of solved by shifting down to 3rd...
- Based on all of this, I've checked the spark plugs a number of times. They do not look too fouled, but I did clean them and even tried to index them correctly. This did not help.
- This brings us to today... she was really unhappy during my last drive this summer. I would not trust her on a drive outside of town, and I know can't take her on the beautiful winding roads of central PA in this condition...
- Your valves or rings are worn, leading to burning oil and grey/blue smoke.
- Your car is running too rich.
- You should check fuel pressure.
- Your carburetors need adjustment.
