1 - 1 of 1 Posts
I have what I believe to be a very good AR 1750 engine (with injection pump) from a 1971 GTV. I have NOT started it but it turns freely and everything is there (including the manifold). I also have the transmission but am sure it will need some help with 2nd gear sync. It goes into second from either end without the grind but only when the car is moving slowly. Finally I have the stock rear end (4:56?) and it's in good condition. I'd like to get $1500 for the engine but if you twisted my arm (gently) you could most likely get the whole lot for that. It's in the SF bay area and if you're interested I can send pictures.
Thanks.
Steve
'63 Giulia Spider
'71 GTV
1 - 1 of 1 Posts
