1971 Alfa Spider. A lot of the mechanical has been rebuilt. I installed the built 2L from my GTV with only a little over 500 miles after rebuild. I am also including the original 1750, with the original Spica pump.
2L engine build
-Steve Hanaford head with 1mm large intate valves, port matched with intake manifold.
-RjR Camshafts
-Motronic pistons
-resized and shot peened rods
-Hastings 3 piece rings
-Aluminum flywheel
-123 distributor
-powder coated valve cover
-vapor blasted block, carbs, intake, oil pan
-euro intake manifold, Italian Webers
-internally regulated altrnatore
-sport motor mounts
Suspension
-sport springs
-Bilstein shocks
-new upper and lower ball joints
-rebuilt a-arms
-Poly sway bar bushings front and back
-new endlinks
-epoxy coated sway bars front and back
-new limit straps and bump stops
Brakes
-new hand brakes and hardware
-rebuild calipers
-new pads
-stainless brake hoses
Exhaust
-new complete exhaust system
-ceramic coated exhaust manifold
New convertible top
There are a few patches on the floors and the outer sills should be replaced.
2L engine build
-RjR Camshafts
-Motronic pistons
-Aluminum flywheel
-123 distributor
-sport motor mounts
Suspension
-sport springs
-Bilstein shocks
-rebuilt a-arms
-new endlinks
Brakes
-rebuild calipers
-new pads
Exhaust
New convertible top
