1 - 5 of 5 Posts
My only keys (I know I should of made duplicates) for my 69 Spider Veloce were stolen with the rest of my stuff in my wife's car this weekend.
I am a bit lost at what options I have to repair this situation ?
- Replace locks (can I still get barrels and keys ?)
- Make new keys (from what ? Can I get the barrels out and have a key made from that ? Is there a code somewhere that may help ?)...
HELP !! I'll take ANY input ... I am in a bit of a bind !!!!
Roland
Spider locks.... stolen
Thanks.. I've seen "SPIDER 1970-93 DOOR LOCK BARREL & KEY" but nothing for early roundtails......:frown2:
Did I miss something ?
Is there a way to find the key code from the barrels ?
Electrical parts part #10408 .
IF you can find a real locksmith (not the key copy guys at the lumber store) AND can get a blank that fits, said real locksmith can make you a new key without taking anything apart. I did that for an MGB we had. The locksmith inserted the key blank into the lock, wiggled it a bit then examined the key for tiny marks with a loupe. He hand cut the key, repeated the above, cut it a little more and in about 10 minutes I had a key that worked.
You might also try contacting Keys4Classics. I know they can cut keys from a close up photo (if you had a copy...). They might also know where to find the code that is supposed to be on the lock cylinder. From that code they can make a new key.
1 - 5 of 5 Posts
