1 - 1 of 1 Posts
Hello! I am currently resurrecting my old spider and have replaced the boosters with new Bosch and new hoses all around from Centerline, and have moved to bleeding the system. Having a great helper (my daughter) pump and hold, we started at the farthest rear and seem to have endless air moving out after many sessions. I noticed that the reservoir with fresh fluid is now dark and old fluid is flowing into the reservoir along with small frothy bubbles. I can see fluid flowing in when she pushes on the brake pedal, although the level does not rise really, so it must be flowing out of the reservoir as well, and back into the system...
Do I now have a Master Cylinder issue?? Have I somehow blown through a seal in the MC? Should I have tried to bleed both front and rear passenger side calipers at the same time with another helper?
Thank you much in advance,
Paul
1 - 1 of 1 Posts
