A project car that is complete. Euro spec car with webers. Much of the work is already done, with many new parts. I didn't recieve any reciepts or documentation, but everything I was told about the car when I purchased it has turned out to be true. The engine and the transmission were rebuilt and crated out of Italy. It has a new clutch assembly, flywheel, exhaust system, etc. I replaced the brake hoses, coil & plug wires and even went through the carbs. I put kits in the brake calipers and master cyl (it needs a new master cyl, though). Starter & altenator have been rebuilt. Cooling system had hardened and clogged up, so I took the engine apart and had the parts cleaned. I had the head rebuilt @ $350. Rebuilt the front seats @ $550. I have driven the car (with no brakes) and the transmission shifts perfectly, with no grinding. It will need a console...I have the gauges and switches, but the plastic was in about 10 peices. The car has rust, but it is certainly repairable. I really wanted to restore this car myself, but due to health related issues, I'll have to pass it on to someone else. If you want to talk, my number is (903)312-6428. If you can't reach me, my daughter's number is (903)948-4672. The car is in Frankston, right outside of Tyler, Texas.
