1 - 5 of 5 Posts
Hi,
I am attempting to wire up an electric radiator fan to replace the engine driven fan (free horsepower) :) - and need to find a source of power to trigger the relay so that the fan will only operate when: a) the ignition is on and b) the temperature sender in the bottom of the radiator says the fan should operate.
Can someone please advise what is the preferred source of this power?
Piggy back off the coil? or go direct to the fuse box and look for a source there? or somewhere else?
cheers,
Ian
Thanks - I already have the wiring diagram that comes in the workshop manual - and will probably get one from papajam in the future - mainly I'm after pointers as to where would be the ideal place to obtain the source of power to trigger the relay from
cheers,
Ian
1 - 5 of 5 Posts
