1 - 17 of 17 Posts
Not for a stepnose, 69 or later for frogeye dash
There were step nose 1300 GT juniors with "frog eye" dash the 2 small gauges in the pod. So likely from a about 68 or 69 GTj. Will suit 1750s also. Not for 1600 step nose.
Ken
The two spoke steering wheel also identifies it as a 1300 Jr. The front wind screen trim is definitely worth salvaging. If you try to pull it out of the gasket in situ you will bend it and render it worthless. The gasket lip should be cut from inside the car to remove the windshield and trim intact together. There are a number of other parts that cross over to other stepnose cars that are worth pulling from this car if you are parting it out.
59' Giulietta Spider Normale- FS, 72' Montreal, 73' GTV under Restoration, 84' Spider, 3.0 V6 Duetto
Webers? Sent a PM with no response. Pic, Price, Condition? Bob
1 - 17 of 17 Posts
