1 - 5 of 5 Posts
I've got 2 Wiper Harnesses that are identical except one has an extra Green jumper wire.
1626050
I don't know if that extra Green jumper is needed.
And I certainly don't know which contacts to connect these wires to on the 3-Position Toggle Switch.
I downloaded this description of the contacts on the Wiper Toggle Switch, but I haven't found a good description of the wiring that attaches to it.
1626059
The Red Wire coming from the Fuse Box was attached to contact 34.
I'm not certain that that's even correct.
1626051
Any help would be greatly appreciated.
Jeff
Jeff, guessing the extra wire is a owner only addition. Pretty common.
I notice the switch has a "wiper" icon. OEM switch was a simple two post on/ off switch and no icon. Wiper motor was one speed.
Cheers, Jon
If you want to use the 3 position switch as a simple on/off then the switch diagram in the above link will enable you to choose a pair of terminals. You have several choices if you do that.
OK. Everything is hooked up and working.
That extra jumper wire is required. (BTW, there was a Bring A Trailer auction of a 67 Duetto awhile back that included a picture of that jumper in the tear down photos).
I drew up a wiring diagram of the completed wiring (with details that the Alfa Wiring Diagram didn't include).
1627801
1 - 5 of 5 Posts
