Sure is dirty underthere.
I had a little click on my Duetto that ended up to be at the Donut where the shaft mates up to the tranny. It took me a while to figure out where it was coming from. I ended up pulling the D shaft at the Donut and putting a dab of grease at the end of the shaft and It was cured. Otherwise U joints and possibly the grease fitting in the spline joint at the center of the shaft.
Beautiful Car. Very nicely done !
Check the donut end first. You have to take the D shaft loose to put grease
on the end.
Good luck!
Stan
on the end.
Good luck!
Stan
