I am starting a new thread for AR*191190 to document information on this specific Alfa.
Below is my original post, and responses, from a different thread.
Keith
PS. The picture of the passenger door card is "as found" condition. It has not been wiped down or cleaned, and the driver's door is in the same condition.
12/12/20
I am fortunate to have recently obtained a 1962 10601 2600 Spider:
Chassis #: AR*191190
Touring #: 10698
Scocca #: 306
Engine: AR00601*01029
31,018 original miles and mostly original paint
The previous owner had it for over 50 years and unfortunately had to stop his restoration of the car ten years ago. He built the engine/transmission cradle. He did overhaul the engine and it's components however I will be checking them before installation. My plan is to do no harm and keep all the patina. I want to make it mechanically reliable, replace the foam in the seats, repair some rust in the rockers, polish the original paint and leave it as is.
I find the many details of the car fascinating, so different than the 750/101/105 Series cars that I am familiar with.
I will be certainly asking for advice in the future.
Very glad to be here,
Keith
[IMG alt="DPeterson3"]https://www.alfabb.com/d2/avatars/m/14/14002.jpg?1573460727[/IMG]
DPeterson3
Push hard and live
Joined Apr 22, 2007
#48 • 3 d ago
I recommend upper body weight training.
Don P
Carson City, NV
[IMG alt="iicarJohn"]https://www.alfabb.com/d2/avatars/m/5/5110.jpg?1573460727[/IMG]
iicarJohn
Joined Dec 28, 2005
Discussion Starter • #49 • 3 d ago
Thank you Keith! Yours is the first 2000/2600 news in a couple of days ... mybe because I am not paying enough attention to drive the study forward? Your info will appear in the next update. And "DPeterson3" ... I am certain that we can all use a bit more training as many of us spend a bit too much time seated at our computers? But then, a bit of mental and emotional exercise should be better than none?
SaveShare
Reply Quote
Like
[IMG alt="touring63"]https://www.alfabb.com/d2/avatars/m/6/6858.jpg?1586594001[/IMG]
touring63
Joined Jun 18, 2006
#50 • 3 d ago
191190 is a great original Car. Gratulation.
Only, I am Wondering that the Engine Compartment is Painted red.
SaveShare
Reply Quote
Like
DPeterson3
Push hard and live
Joined Apr 22, 2007
#52 • 2 d ago
I've had two, red 10204's. For ONE of them, it was the original color. The original lacquer paint would never survive this long without being stored in a nitrogen bubble, in a lightless room.
Don P
Carson City, NV
[IMG alt="tubut"]https://www.alfabb.com/d2/avatars/m/0/752.jpg?1573460727[/IMG]
tubut
Joined Sep 11, 2003
#53 • 2 d ago (Edited)
Welcome to AlfaBB, Keith!
Great pictures and story on 191190. The car is obviously (to me) an early USA model that probably would have been delivered with 102 hubcaps.
The engine compartment (inside and/or below the aluminum trim around the edges) being painted in body color is a bit unexpected, if not puzzling -- but so is the fact that the scocca badge is mounted on the inside of the support bracket for the rubber stop for the engine hood (not below the bracket, where it can be found on other cars), almost as if the bracket was welded on after the scocca number had been installed (how else could the screw holes have been drilled in that location?).
Whether or not the paint is factory original or a result of the body having been worked on 40-50 years ago is a question that will have to remain unanswered for now. Maybe this car is an example or witness of Carrozzeria Touring learning and adapting to building these models and optimizing the production line. It would be interesting to see what the underbody of the car looks like and to measure whether or not the horizontal openings next to the center grille are at the same height (the passenger side opening usually is 3/8" to 1/2" lower than driver the side). I would suggest you to do that in a separate thread (just for this car) where we may be able to discuss the car and answer any questions you may have about it and/or getting it back on the road.
BTW, the first and only occurrence of 191190 being listed in the 2000/2600 International Register is in 1995, when it belonged to a Dan A. Riddell (of Tulsa, OK) who submitted it as being in original condition with a 4 out of 5 rating for each of body, interior, chrome and mechanicals (see online version here).
-Ruedi
'63 2600 Touring Spider (AR 191437, the car that started the 2000/2600 International Register, reassembly in progress)
ex-'65 2600 SZ (AR 856043, the car in my avatar, sold as resto project to Austria)
Maintainer of a private 2600 SZ register (not the one in the Netherlands).
iicarJohn
Joined Dec 28, 2005
Discussion Starter • #54 • 2 d ago
Thank you "cast iron 2000". Your info is entered and should appear with the next update.
For those who believe all of these cars should have been finished absolutely consistently, I don't believe we can know that at this point. Some fairly unexpected things have happened in the factories of many manufacturers that were probably far more typically "constrained" than either Alfa Romeo or Carrozzeria Touring in this time period. When in doubt, I would tend to retain 'what is' rather than make the car fit the expectations of others based on experiences with a limited cross-section of cars. A correction can always be made during a restoration if required, when more evidence is in?
When we learn the initial destination for 191140, we may just learn something meaningful that may give us pause for thought? I spent a few hours taking imprecise notes from one Giulietta "Spaider" ledger and there were quite a number of unexpected variations from "normal" alluded to during less than the one year's production the ledger described.
tubut
Joined Sep 11, 2003
#55 • 24 h ago (Edited)
Having had a closer look at the picture of the engine compartment of 191190, I get the impression that there is indeed some black paint under the red paint in some areas (as shown in cropped image below). I would expect these areas to be part of the telaio/pianale (delevired by Alfa to Touring) while the areas on the outside (to the left) of the radiator and near the hood latch show yellowish-green-beige primer (which probably was RAL 1000 or maybe even the darker RAL 1020 in color) that would have been supplied/installed by Touring.
-Ruedi
Keith
12/12/20
Touring #: 10698
Scocca #: 306
Keith
DPeterson3
Push hard and live
Joined Apr 22, 2007
#48 • 3 d ago
Don P
Carson City, NV
iicarJohn
Joined Dec 28, 2005
SaveShare
Reply Quote
Like
touring63
Joined Jun 18, 2006
#50 • 3 d ago
SaveShare
Reply Quote
Like
DPeterson3
Push hard and live
Joined Apr 22, 2007
#52 • 2 d ago
There is a good chance the current paint is NOT original. Furthermore, a body-color engine bay for a 102/106 pretty much guarantees that a lot of work was done prior to the repaint.touring63 said:
Don P
Carson City, NV
tubut
Joined Sep 11, 2003
-Ruedi
iicarJohn
Joined Dec 28, 2005
tubut
Joined Sep 11, 2003
-Ruedi
