1 - 14 of 14 Posts
1958 to 1962 Alfa Romeo spyder 2000 cast iron engine block and 5 speed trans available for $2,000.00
Its in Secaucus, New Jersey Pick-up only
Discussion Starter #2
Alfa Touring 102 Engine Block,pistons,crank shaft,oil pan,trans
Alfa Romeo 2000 touring spyder 102 (un opened) cast iron Engine Block, pistons, crank shaft, oil pan, 5 speed trans. and Generator all included for $2,000.00 Firm.
, RIP 04/21/2019,
What is the history of this engine?
Thanks, Roger.
, RIP 04/21/2019,
Can you post some photos to give me an idea of what you have?
Thanks.
FWIW, this is a casting number, not the engine block number.
Push hard and live
The engine serial number, if it matters, is stamped (not cast) on the front of the block just below the cylinder head on the right side above the water pump.
Discussion Starter #12
Alfa Romeo, 2000, touring, spyder, 102,
Still available 3/8/2012
1 - 14 of 14 Posts
