1 - 10 of 10 Posts
Refresh my memory - they're both a 6bolt crank aren't they - flywheel is interchangeable?
Not interchangable.......
Not the same bolt count.
In the USA cars, the 1750 models (1800cc) had the same bolt pattern as Giulia 1600 or earlier 1300.
Down under, I don't know.
Discussion Starter · #6 ·
1750 105 and Alfetta 1800 are not the same bolt pattern. That's why i asked the question in the Alfetta forum.
In the old days of the Digest this would have been done and dusted in under a day... seemed to be covered every couple of weeks...
Richard Jemison
1800 vs 2 liter... Not 1969-1971 early 1750
I think these later small motors shared driveline components with the later 2 liter and the crank "should likely" be similar to the later 2 liter.
The design of the early 1969/71 1750 engine was an interim "fix" at the time, and shared early design to save $.
Which "1800" are you dealing with?
The Alfa 90 type (bore/stroke80x88.5) or the 155 version (84x80)??
These were never sold here so no direct exposure.
Discussion Starter · #8 · (Edited)
Alfetta GT/Sedan - 72 to 83 - same bore and stroke as the 1750, so 80x88.5
Discussion Starter · #9 ·
1 - 10 of 10 Posts
