I need the opinions of the board because I am completely stuck on a decision I need to make asap about whether to go 1750 or 2000 on my car. I have both engines sitting in my garage now. The 2L is out of a early 70's Spider and is mostly complete (flywheel, starter, etc)
I purchased my car with a 1750 conversion, weber 40's, euro 10548 cams, and a Centerline distributor with several selectable advance curves a few months ago as some may have seen on the Sedan forums. I recently pulled the engine out of the car to stop some leaks and I discovered the the engine will be needing more than just a mild refresh and I want to invest the money on the right engine, I'm inclined to go with the 2L.
I really want to build a performance engine for it that will work for my needs. My car will be driven on the street 60% of the time, back roads and canyons 30% and track/autocross 10%-if that. With the 1750 in it around town and traffic it was fine, but when I was driving aggressively the lil 1750 left me wanting more. There are some quick little Datsun 510s and Toyota Corollas in my neighborhood that I'd like to be able to chase down!
So here is my question, I understand the cool factor of the slightly higher revving 1750, and I know it is desirable by the racers, but the 2000 seems to have a lot more ease when it comes to piston choices, etc
I have both a 1750 and 2000 in my garage at the moment....which shall I proceed to build???
My short list with either 1750 or 2000:
-I want to raise the compression maybe a forged piston set?
-I want some more aggressive cams (euro cams didn't quite do it for me)
-I want to run my 40dcoes at least for now
-I will do at least some porting to the head, (I have some experience)
-I will probably run the Alfaholics full SS sports exhaust system
-I have a Pipercross air filter setup with air horns and that I bought from Alfaholics as well
Can someone recommend a good combo of pistons/liners, cams, etc that will give me power but still be streetable and run on 91 octane California gas?
Thanks!
Thanks!
