1 - 2 of 2 Posts
Multi-angle valve job, new valve seats, oversized stainless steal valves, manganese-bronze valve guides, Teflon seals, Iskenderian high performance springs (will accommodate any high lift cams). All ports cleaned up, less than .010" has been machined off head heigth, never ran. Decided to go with 2000, never got around to assembling the 1750. This head is perfect. $550.00, obo. Call Dale, 303-667-6174.
1750 Head
Hi Dale,
Hi, I see you have an old post but wonder if you still have the head/valves.
If you do has there been much porting work done on it? How much does the .010 bring compression ratio up by?
Thanks! David
1 - 2 of 2 Posts
