1 - 2 of 2 Posts
Does anyone know if a Giulietta veloce oil pan and pump will bolt to a 1750 or 1600 without modification?
Thanks...
Cast Veloce Spider sumps.
The aluminum multi part one? one? Yes if you have the pump and connector from the pump to the cooling passages in the bottom. There are some minor fit issues, I have covered this before, in another thread. Where is your dipstick? Which one is it? Does your middle main cap have "ears'? They must be cut off or another cap fitted with align boring, if you want to use the veloce windage tray. (It's a good one). Is your pan complete with the trap door box in the middle? Are you using Veloce mounts or Centerline's dropped mounts for the 1750? Do you have the updated pump? It goes on. As I have used a lot of these sumps, I know them all well. Feel free to ask me any questions. I would be happy to answer. I LIKE these sumps:cool:! :DGordon Raymond
1 - 2 of 2 Posts
