I picked this up a while back and now decided I do not have a further use for them. I have limited expertise in this area so I will provide what information I know. They came from Canada so could be for carbs or Spica. The cams do not have a factory stamping so are probably regrinds. Stamped A33 with ALQUATI directly below. They were separate from the head so may not even belong to this head. The head has all the valves, springs, guides, missing one follower. No cam bearing caps. Visual inspection does not reveal any cracks.
Selling "as is". If interested shoot me an offer, or if you have any further knowledge,I am interested.
Thanks, Jon
You can tell whether it was spica or carb by the length of the studs on the upper outside corners on the intake side. Carbs were shorter then the spica ones.
But the studs can be easily changed to put whatever intake you want on it.
