1 - 5 of 5 Posts
I have a tone of 1750 engine parts, all bottom end.... rods pistons, bearing caps and 2 very good condition 1750 cranks. I can get the specs if you are interested and send photos. I would like what APE is charging for the cranks $500 ea.
Located in socal.
and yes the photo above I grabbed off the web.. its not the actual photo of the cranks.
I think a freshly ground crank is worth more than $700.00. The cost to mag a crank, grind and heat treat is $400.00 if you use Marine Crankshaft. I was told by Marine that if the crankshaft is not correctly ground it cannot be placed in service. I have been rebuilding Alfa engines since 1968 and if engine parts are not properly machined the engine will probably fail. I learned lessons the hard way and know what happens when you do not follow Alfa guidelines or ones set up by the parts manufacturers.
1 - 5 of 5 Posts
