1 - 5 of 5 Posts
00551 06934Block with main caps - Needs Line BoreBerlina/Spider/GTV 71
00551 02564Block with main capsBerlina/Spider/GTV 70
00551 00554Block with main caps Berlina/Spider/GTV 69
00551 1898Block with main caps - # 2 cap steal sleeved - OKBerlina/Spider/GTV 69
All with good deck surface, main bearing saddles vary, cylinder head studs and block base to liner seal surfaces.
No corrosion or oxidation.
Race car cores stored for years.
I have Bat wing pans, core liners, water pumps etc. to go with blocks if needed.
Can box and UPS for reasonable rates. Figure 50 pounds in a 20 x 20 x14" Box from 14543 Zip
Or I get to most SVRA/VRG vintage races ( when things open up ) in the East. As well as Alfas at the Glen if its open.
Contact me directly if you have any questions.
$400/pc or Best offer plus shipping.
Other stuff...
One 1750 core head left. Original deck height - UNPITTED unmachined. Needs guides installed and intake and new exhaust valve seats machined. Can supply new valves/guides/seals and all other hardware as well as the nice early Euro/Fi 10502032001 Cam assemblies. $250 for the core / $500 BO for everything.
One Alfa Factory Forged fully counter weighted Race Crank. Oil passages drilled, thredded and plugged.
Rods standard dimension but need to be cut. Unique Bob Wts and balance for high RPM applications.
Believe it to be 10541.02.010.99 88.5mm stroke - so its good for both 1750 and 2.0L $800 / Bo
call or email direct if you have questions.
Chris D
585 330 5456
[email protected]
1622963
1622964
1622966
1622967
1622968
1622969
1622970
1622971
Discussion Starter #2
Sorry - Crank can only be used on a 1750 - forgot about the different bore spacing...
Chris D
1 - 5 of 5 Posts
