401 - 414 of 414 Posts
Discussion Starter · #401 ·
Today I checked the liner protrusion. I put an old liner in and clamped it down using my home made liner clamp tools. (Basically aluminum tube and fender washers) then I took my deck block for checking piston protrusion typically and zerod my dial indicator on a flat surface and measured the protrusion of the liner above the block with no o ring gasket.
Automotive tire Light Motor vehicle Valve Clock
Motor vehicle Hood Automotive tire Automotive design Automotive lighting
measured .002 on both new and old liner which is good. May try again with an o ring to see the difference but I’m not sure if it’s worth using one just to see.
Moderator
1991 164L
Yes they are different shafts.
Moderator
1991 164L
Today I checked the liner protrusion. I put an old liner in and clamped it down using my home made liner clamp tools. (Basically aluminum tube and fender washers) then I took my deck block for checking piston protrusion typically and zerod my dial indicator on a flat surface and measured the protrusion of the liner above the block with no o ring gasket. View attachment 1702185 View attachment 1702186
I noticed that the fitting/connector coming out of the block for the oil port has a groove for an oring. That fitting is not shown in eper parts breakdown of engine block or the lubrication system so the oil ring isn't shown either. The big 234035067 oring ITEM 3 I found in Italy is the only one shown but it goes in the groove in the 60562302 (5-spd) 60808390 (A/T) engine support.
7
Q
15-.P
_i
8
2
10
Gesture Font Line Art Auto part
White Font Line Auto part Parallel
Moderator
1991 164L
ENGINE BLOCK
7
Q
15-.P
_i
8
2
10
7
Q
I noticed that the fitting/connector coming out of the block for the oil port has a groove for an oring. That fitting is not shown in eper parts breakdown of engine block or the lubrication system so the oil ring isn't shown either. The big 234035067 oring ITEM 3 I found in Italy is the only one shown but it goes in the groove in the ITEM 4 - 60562302 (5-spd) 60808390 (A/T) engine support.
7
Q
15-.P
_i
8
2
10
7
Q
15-.P
_i
8
2
10
8
2
10
Discussion Starter · #405 ·
So I took that O ring off and kinda screwed myself. I don’t think it’s an o ring. At first I thought it was an oring that hardened from heat etc. but when I tried to take it off it cracked. It seems like it’s a plastic ring. Which is bad for two reasons. One plastic doesn’t stretch so no way I could install a new plastic one. And two the part number doesn’t exist. So now the question is why wouldn’t an o ring work? I would presume it should after looking at both ends of where it’s sealing it looks like it separates oil going into the filter from oil coming out of the filter. So no reason it needs to be plastic right? Let me know what you guys think. The other option is take that fitting off one of my spare motors. But I tried a wrench on it and this fitting is F’ing tight. I even found an old thread on gtv6.com for a 24v swap where they had quite the time removing that fitting.
Automotive tire Engineering Machine tool Automotive wheel system Auto part
Hand Automotive tire Tire Finger Thumb
Moderator
1991 164L
That sealing ring looks like it must be something like teflon and I have used a heat gun to remove and install teflon seals. I wonder if looking up 24v engines for the GTV or 166 would should that fitting and the sealing ring.
I can open my old eper CD anymore on windows 10.
Discussion Starter · #407 ·
I only have the cardisk manual for 164 but I can look on totally Alfa’s site that has free 916 manuals I’m not sure if they have a parts IPC but they have maintenance manuals I’ll check.
Moderator
1991 164L
OK looked up 155 V6 engine on the online Eper and it shows index A item 10 as 60515427 connection and item 18 to be 14457280 oring seal that go into engine block at point A
Font Line Auto part Parallel Engineering
Here is 155 V6 engine mount with item 16 the same oring 234035067 as 164 24v
Font Line Auto part Engineering Technology
Moderator
1991 164L
Discussion Starter · #410 ·
Found one Fiat 14457280 oring in IT O-Ring Earpiece tube petrol injector Fiat Uno Turbo i.e. 1.3, 1.4 [5514.20] | eBay and similar one in KY USA 87035S94 - A New O-Ring For A Farmtrac 35, 50, 55, 60, 80, 435, 535 Tractors | eBay
I have a feeling though the oring is for the threaded end of the 60515427 connection and the sealing ring is part of that part number.
Ordered that one about 2 minutes ago haha. We’ll see how it looks when it comes in. This one was definitely a hard plastic but I think it makes sense they were updated to an o ring. I also ordered the driveshaft bearing on eBay p/n 60801307.
Moderator
1991 164L
That 14457280 oring is used on inner threaded end of fitting oil filter screws onto outer threaded end so I am pretty sure it won't be correct size for groove on 60515427 fitting you took hard ring off of prove me wrong. It is item 2 in picture and goes on item 7.
Product Font Auto part Engineering Cylinder
Discussion Starter · #412 ·
oooooh, didn't think that one through hahaha. but if that's the case ill take the fitting off my spare block and use it with that new O ring. I found the p/n and got excited not realizing it was the seal under the fitting. oh well, well see how it goes.
Moderator
1991 164L
Item 10 in engine block picture 60515427 - CONNECTION fitting that goes into engine block at point A. this info from old 2004 eper​
Availability:​
- Product orderable
Family:​
AX02 - DIFFERENT PRINCIPLE MOVER ITEMS
Macro family:​
A
Discount code:​
B
Minimum quantity per package:​
5
Unit of measurement:​
Num
Weight (grams):​
30
Listed price:​
3.02 GBP
Price including taxes:​
3.55 GBP
Product previously in use for: 60515427 CONNECTION
Substituted​
Substitutes​
60807803​
CONNECTION - Replacement date:06/2003​
Prod. code​
Desc.​
Min. qty​
Repl. Ratio​
60515427
CONNECTION
1
1/1
Discussion Starter · #414 ·
Are the 12v and 24v crankshafts the same? My machine shop called me and wants to know the counterweight’s weight. I have this chart but don’t know if it applies to my 24v engine.
Font Publication Book Paper Paper product
