Looking for advice on bleeding the clutch on my 164S. I had to replace a bad clutch slave cylinder and can't bleed the system using my pressure bleeder through the master cylinder. Maybe it requires reverse bleeding???
Also have a couple of other issues:
brake lights are on constantly, does not go out with the brake light switch disconnected, only when I disconnect the main connection.
wiper fluid warning light is on even with wiper tank full of fluid
Air bag warning light is on
Oil pressure gauge is showing no pressure, I suspect the connection at the motor is off, where is it on the S motor?
Any help is appreciated, thanks.
