Just discovered that my 91 S with 67k front right strut is bleeding fluid and has no dampening ability now, just bounces up and down. Any solutions for this problem- rebuild- new-used? Thanks for your help.
Koni's all around if you have the money, otherwise look for another used. Had to for a leaking rr strut.
does anyone know (perhaps Alfisto Steve or Jason) if you can use 164B/L front struts in an S? My electronic settings haven't worked in years and the front suspension is kinda soggy.
My 164 is the cruiser of my inventory so I don't need a full DTM set up. Thanks for any input!
You can use standard struts or Koni. Standard actually cost more than koni.
But you need donor struts for the front inserts from a L or LS.
Koni can be adjusted to exactly like stock or sport mode if you like that. Nice!
I have them in stock. May even work a deal on them.
Jason
Yeah Koni sounds like the way to go, now I just gotta be patient and lurk around for some donor L/LS struts. Do you have any laying around for sale?
Not anymore. Sorry. Could fashion something up with the old electronic though.
See your PM.
