1 - 9 of 9 Posts
164 RPM/Timing and Coolant Temp Sensor Info
S31 in wiring diagrams is RPM/Timing Sensor and has a 3-wire Bosch connector. It is located next to toothed front crank pulley and has preset (NON-ADJUSTABLE} air gap of .020" to .050" (.5 to 1.5mm). The resistance check is between 3-WIRE CONNECTOR center pin and outside pins. You will get no reading open between center and one outside pin and about 0.6 k ohm between center pin and other outer pin.
As for tip of sensor it is magnetic.
S7 in wiring diagrams is Coolant Temp Sensor amd has a 2-wire Bosch connector. It is located in mid thermostat housing at a 45 degree angle under top radiator hose that is attached to thermostat outlet (hidden from view from top of engine). It is not 2-spaded terminal equipped temp gauge and red light sender facing forward next to timing belt cover. The resistances shown in temp chart below are a little off from actual resistances usually found. 0C/32F is 6.0 kohm, 20C/68F is 3.0 kohm and 100C/212F about 200-300 ohms.
Attached pictures are from 24v shop manual but sensors are in the same location on 12v models.
Steve,
Do you happen to know a current Bosch part number for the RPM/Timing Sensor for 12V (91-93) engines?
Simeon T
164 12V 04 S31 rpm/timing sensor 60560715 BOSCH 0261210047
Steve is it possible to check the Timing sensor with a digital multimeter?
My car died last night - checking around for missing voltage etc - currently I have no sparks happening - I checked the leads from the timing sensor to the Motronic unit - I'm reading nothing (open circuit) - not sure if this is a magnetic unit or some kind of hall effect device (I tried checking using the diode function - no reading)
Any help appreciated on this "no sparks" problem
Cancel Red Alert :rolleyes:
I just checked the wiring harness back to the Timing sensor - that plug/connector ( passenger side next to timing cams on side of wheel arch/strut) for the sensor had drifted apart - pushed it back together and I've got sparks and a running car.
Mac...
Yes, check resisance between center pin and outside pins. You will get no reading open between center and one outside pin and about 0.6 k ohm between center pin and other outer pin.
Mac...
Glad you found a simple fix.
Yes, check resistance between center pin and outside pins. You will get no reading open between center and one outside pin and about 0.6 k ohm between center pin and other outer pin.
Thanks for the info Steve, that's good to know for future reference. I wasn't able to source that on the net.
Thank you Steve.
1 - 9 of 9 Posts
