1 - 20 of 23 Posts
Sale. Will be adding parts all weekend.
NOS/used parts for the 164.
OEM Head Gaskets 12V and 24V
NOS OEM:
60548751 - OEM 24V L. head gasket- $99.00 (1 available) 164, 145, 156, 166, 3.2...
60569896 OEM Head Gasket-Right-12V engines- $68.00 (1 available) Milano, 164, GTV6,
60569900 Head Gasket- Left- OEM 12V engines- $68.00 (2 available) Milnao, 164, GTV6
164 24V Intake air hose. 60578720. LAST ONE!!! $210.00
164 S (QV) 12V Intake Air hose- OEM - LAST ONE!!!!!!! 60547303 >>>>>>> $225.00
164 Windshield washer/headlamp washer motor- NOS- $289 now $250.00
164 12V OEM Alternator Belt- $19.00
164 OEM wiper blade set- $32.00 (3 in stock)
Brake calipers front L/R-Rebuilt- 12V- $50 each, 1x24v NOS $99.00
164/Milano/75 12V Factory OEM waterpump $249.00
60589771 CABIN AIR TEMPERATURE SENSOR-164 NOS $40.00
60559862 THERMOSTAT-87˚C, NOS/OEM, 164- $119.00 LAST ONE!!! (Neoprene seal) 1x used $25.00
OEM Sekurit windshield- heated. $650.00 Last one!!
NOS Hood Cable with grommets- $75.00
NOS Gas/Brake pedal covers- Alfa Logo- $18.00 each (2 left)
NOS 1995 wEGR (or 1994) ECU- $775 now $550.00
12V Cap and rotor- BOSCH- $85.00 (SOLD)
Automatic ZF transmission filter. $75.00 (SOLD)
NOS Front Fender well (brake/ABS cover)- $10 each
NOS Recaro Seat Motor- $165.00
NOS recaro lower rail plastic trim- $15 each (2)
DENSO Heater core- $75.00
164 Exhaust Hangers- $2
164 Twinspark- 4 lug Rear hub- $25 (FAG GERMANY)
164 12V Brake rotor PAIR- $40.00 (1)
164 Q4 Rear brake pads- $35
164 Q4 rear caliper pair- $375.00
164 Q4 rear brake rotors Pair- $250.00
164 Steering rack with damper Boot KIT- $40.00 (SOLD)
164 12V and 24V Emergency Brake cable- $55 each
164 All- HVAC Blower Motor- BOSCH- $110.00
USED Front 91-93 B/L/S Fenders_ $40 each
USED LS front bumper- $250
USED LS Rear Bumper w/tow cover- $250
USED Window regulators- $35 each
USED 164 Glass- $45 each (small rear $20 each)
USED Blower motor with blade/Housing- GOOD- $50
USED Outside door handles- $20.00 ask for side/front/rear
USED A/C Fan speed regulator- $50.00
USED Trunk release- $20
USED Gas Release- $20
USED Auto trans- 1994> $100.00 (Scrapped)
USED Auto trans shifter cover- $35
USED Auto Trans Speedo sensor- $40.00
USED Rear speaker covers- $10 for both
USED Headlamps $30 each Mostly 24V/1 12V
USED 12V radiator/Blackstone brand (thicker)- $50.00 (Scrapped)
USED Good OEM coolant Tank- $60.00
USED starters- Various mileages from $60-100
USED 24V Brake Booster- $50
USED sunroof motor- $25
USED Airbag Sensor pair- 164 24V- $60
USED VARIOUS COMPUTERS- $30-50.00 (Cruise, ABS, Brake lights etc...) Ask
USED leather shift Boot S and Q/LS- $40.00
USED B/L Airflow meter- $25
USED LEFT SIDE OUTER LS/Q MIRROR- $150.00
USED B/L Wheel- $45 each (x3)
USED B/L/S Climate control panel- $40.00 (x5 available)
USED 12V/24V fuse box- $50 each
USED LS rear bumper Chrome trim - center- $50.00
USED AUTO trans ECU- $50.00
USED SPEEDO CLUSTER- 12V/24V- $40.00
USED Mechanical Timing belt tensioner- 12V OEM- (approx- 5K miles) - $45.00
USED 164 Wiper assemb. $60.00
USED Front Spring perch, L/R $40 each
USED AUTO TRANS Cooler braided hoses- $75.00
ASK about any used item, too many to list.
Something you don't see? Ask. Lots and lots of parts new and used on sale.
60561378 AUXILIARY BELT VIBRATION DAMPER PIVOT BRACKET - 24V- $260 (2 in stock)
24v Engine- OIL PAN NOS- $650, now $450.00
Various OEM Main and Rod bearings, not full sets.
60568882 RED MAIN- $18.50 each
60513381 RED Rod -$15.50 each
1 x ROD BEARING- V6 .020, KING BEARINGS- $80
MAIN BEARING- SET (STD) KING-2.5/3.0L- $149.00
60513907 AUX. BELT TENSIONER PULLEY- OEM 164- $99.00
Lots of stuff still.
Or not?
Got any NOS non-clearcoat black paint (pre-applied to my car)? :)
Dave do you mean the TOUCH-UP Black 164 code 601 p/n 0060707898 net contents 1/2 FL OZ VIAL that is founding the OWNER'S MANUALS PACKET?
I still have them in both BB1 and BB2 packets.:laugh2:
Gosh, I miss old Earl Scheib. Will never forget an old VW Beetle that came out of one of his shops, bright yellow - including the tires.
Yup, quality paint jobs. Had a friend with a van, was going to take it in for a new spray. He made the mistake of taking it camping the weekend before He forgot to wash the rocker panels and fenders off, and when he got the van back from Earl Scheib, they had painted over the all the dirt everywhere.
However, not related to Jason's sales. Still need to order several parts from him, as soon as I get my needs squared away.
Discussion Starter #14
I have a ton more parts than this on sale, so just ask. Normal maintenance parts are not on sale so don't ask about timing belt stuff, water pumps, etc... ;)
Looking for 164 'S' intake tubes -- 44mm. And if you don't have any, what is the going price for a set?
Thanks.
You mean the 45mm 94/95 Q runners? The 91-93 S runners are 39mm IIRC. The Q runners are not compatible with the 12V engine without extensive modification to the heads, and cams because of air mass flow changes, I would guess.
"I am asking about the 45mm Q intake tubes "
What car are you planning to use them on, out of curiosity. If you don't mind, that is.
1 - 20 of 23 Posts
