Hi,
Have posted before about disappearing segments on a 1995 164 3.0 24v. Have today pulled out the console with a view to swapping the ribbon cable/LED itself from a 1995 16v twinspark 164. Both UK spec. Surprise, surprise for an Alfa - there are significant differences, despite the view from the front of the displays being pretty much identical (just slight colour differences on the needles and different red lines for the different engines).
The LED ribbon cable differences are so huge there is obviously no chance of swapping any part of these over. Nor can I see any obvious evidence of where the connection issue might be on the 24v unit. I've got to the point where I'm considering just dropping the 16v unit into the 24v car as is. All the physical connections on the side of the unit look the same but are they truly compatible?
Thinking the redline differences shouldn't be a problem as the rev limiter is controlled by the ECU but what about the speedo? Are the final speedometer feeds on both cars the same? Measured per turn of the wheel?
If you look at the pic of the fronts, you can see the auxilliary dials on the 24v settle towards the middle while on the 16v they settle towards zero. Significant or just a positional issue while they are out of the car?
Why did Alfa have to make things so hard....?
