Hi,
having seen how deeply the throttle cables are buried (even worse on RHD cars than LHD ones) does anyone have any tips on the best type/grade of oil to drip into one?
Keen to do anything to preserve the life expectancy.
Thanks.
How about graphite so it doesn't attract and hold dirt?
graphite is conductive. I'd use sewing machine oil or 3 in 1 with the long flex spout. ciao, chris
I use a cable luber similar to the one shown below and a spray can of TriFlow lubricant.
Cable Luber
Most motorcycle shops carry cable lubers.
Thanks, guys.
Not sure why graphite conducting would be a problem, unless thinking of possible oil running through and dropping onto the electrics inside the car.
Light oil like 3 in 1 is an option. Specific lube for cables sounds even better. One of my concerns was an oil degrading the inner sleeve that runs inside the cable casing. Hopefully a specific cable lube would have stuff that allows for that. Or am I just being over cautious and 10w/40 engine oil would be fine?
I guess 10W40 would be fine but being in England you might consider a 0W20 or a straight 10W for year round use. OTOH, it is warm under the hood so maybe a 50W is more appropriate. s/o. I didn't realize they made cable lube but thinking about it, it does make sense. I'd go that route. ciao, chris
