Try cleaning, and protecting with dielectric grease, EVERY electrical connection in the engine compartment as a first simple start.
Thats an idea. I will check the wires and connections.Try cleaning, and protecting with dielectric grease, EVERY electrical connection in the engine compartment as a first simple start.
Nope. The light didnt flicker a single time when these cut outs occur. And the tempature from the gauge seems plausible. Never jumps or signales something strange.oes the coolant over temp red light come on and flicker as seen in your video sometimes when the tach needle fluxgates?
What I'm thinking about is his comments about this happening mainly in wet, cold weather. If it had a Lucas system, I'd understand it completely!While everything above is certainly necessary, I second Dave's thought about the coolant temperature sensor.
Pretty sure thats good, yes. I have cleaned that from oxidation and used new fasteners. The intake plenum is not mounted on rubber mounts. So ground there should be fine.Wait a minute, have you verified you have good grounding of Fuel Injection system wires G131 grounding bolts to end of intake plenum and that intake plenum is also grounded to valve cover or engine block? Later models intake plenum set on rubber mounts so not grounded to engine unless a ground strap from throttle body allen head bolt to rear of head.
Prolly you got the wrong gauge/red light sender for the 91-93 164 so red light dot will stay on. I bet you got one for GTV6/Milano(75) and 94-95 164. There is one of the correct ones for 91-93 on Taiwan ebay now but shipping very high.So... new ground cable installed, still the same. The ignition switch and cables are looking good, nothing burned or loose.
The drive back home from my workshop was a nightmare. Very foggy weather this evening, so it was stalling like hell. And: Not before 60° Celsius. Cold she was running fine despite the weather conditions.
The two relais looking good as well. I guess you mean these?
The car is on the road for ~6 months now and i never had this issue. Only now in cold weather. I also tested the MAF. While running i pulled the plug and the engine instantly stalled.
BTW, what is very weird to me is that since the temperature sensor (For the gauge) is new the red warning light is always on. But other than that its working fine.
Steve, isn't there an air temp sensor built into the AFM? I know the Motronic system on my S4 Spider has one, and the fault code on that is 1221, as I recall. What if that temp sensor isn't reading the colder air correctly??? Have you seen that happen with any of your 164s?Prolly you got the wrong gauge/red light sender for the 91-93 164 so red light dot will stay on. I bet you got one for GTV6/Milano(75) and 94-95 164. There is one of the correct ones for 91-93 on Taiwan ebay now but shipping very high.
You can turn out the over temp red dot light by disconnecting wire (small terminal) from sender and ground it to engine or chassis to keep red dot off.
I guess you need to jump red wire to brown and pink wires at ignition switch connector and see if your cutting out issue stops.
Well then, based on the symptoms described, I think he should run the diagnostic routine using the pushbutton, and see what codes pop up. After all, this rough running seems to be connected with ambient air temperature. I could be wrong, but I think it's worth a try. If he has access to another AFM, he could change them out and test by substitution, also.Yes there is an air temp sensor in AFM.
