Stu, I'm surprised the TI isn't being restored since they are quite valuable.
I'm in the process of purchasing a set of uprights/hubs from another fellow. I did not ask him about this, but it is conceivable that I might need complete front suspensions. The '66 GTV sustained some pretty major front end damage, primarily under the car - which affected the subframe. The car has been straightened, but the right suspension is definitely out of whack as in the bottom of the wheel is splayed out. The damage was mostly on the right (passenger) side but the hub is definitely bent on the left side. I installed a new cast wheel on it and it wobbled when spun. I installed the same wheel on a '69 Spider in my shop and it ran true.
My problem is that I won't have access to the suspension until the bodywork is completed - but my fear is that I end up with a (client's) car which can't be aligned. If I completely replace the front suspensions I'll eliminate that factor, but at what cost?
I'll add that it might be possible that the suspensions are slightly 'tweaked', not noticeably, but enough that they need to be replaced to align the front correctly.
My plan is to retain the Dunlop brakes - front and back, but might have to shim the wheels out somewhat.
We can continue this discussion here, but if you'd like to 'talk' directly, email me at
[email protected]
