A fan kicks on at low temperatures (180 degrees could be less). I have A/C but compressor is taken out so I can't use it.
As far as I know there are only 2 fans, the Main Mechanical one and the electrical one at the A/C evaporator(?)coil.
When the fan I'm speaking of activates why does it sound like it is coming from the EFI? Is there another cooling fan for the EFI system that I cannot find in the shop manual or anyother resource? Or is it just my old ears not able to pick-up the fan noise source?
Since I do not use the A/C (although if it wasn't so darn expensive to fix I would) I'm contemplating removing the entire A/C system, is there any mechanical disadvatage to this since I would be removing the electric fan along with the A/C system?
I will also post a thread question re: how to defog without A/C.
