Hi
Please can someone confirm if the upper sump pan of a 105 Sprint GT Veloce is the same as a 105 1750 GTV ?
Also does anyone have a 1750 GTV parts list on PDF that I could have a copy of please?
Many thanks in advance!
It's not. Same overall dimension but 1600 have 6mm attachment, including studs along the front part. 1750 and 2000 are 7mm attachment, bolts all the way around that thread into the pan or through the pan into the block. No studs.
Early 1600s have two different depths of bottom pieces, and early 1600s have two bolts across the back, late have four. All 1750 have four.
